Beosound 1 clock problem
This post has 6 Replies | 0 Followers
marexy
Posts 710
marexy Posted: Sun, Dec 22 2019 8:35 PM
Hi
I have strange problem with my Beosoud 1
All is working fine, CD, FM radion, AUX ..
but..there is no clock!
If i go step by step as by the manuals nothihg happened.
Can't se clock on the dispaly.
any suggestion?
marexy
Posts 710
marexy replied on Mon, Dec 23 2019 7:20 AM
Nobody have Beosound 1 anymore?
lawrencejmcook
Posts 742
I do, but not with me.
Suggestions:
- Are you using your usual remote? Could remote be accidentally set to LINK mode?
- Does BS1 have an internal Lithium battery that is now dead?
- Does not clock need to be set while unit is in stand-by?
Lawrence
hemenex
Posts 569
hemenex replied on Mon, Dec 23 2019 9:23 AM
could it be this is MK1?
As far as I remember only MKII had the build-in-clock.
Pressing << and >> in standby leads to what?
AU -> MKI
clock: MKII
(In MKII you have to press CD< and CD> to get AU)
HTH
  hx
marexy
Posts 710
marexy replied on Mon, Dec 23 2019 11:29 AM
Thanks guys
Than my is MK1...and no clock....shi..t.
I din not know there are MK1 and MK2
How can i check that?
By type or serial number?
b.r.
hemenex
Posts 569
hemenex replied on Tue, Dec 24 2019 10:36 AM
Just do what I recommended. .Press << and >> (simultaneous) in Standby.
pretty sure it will display "AU" (=AUX) if it's a MKI
Don't know about type number differences but I think SW2.0 and up is MKII
  hx
altist
Posts 72
altist replied on Tue, Dec 24 2019 1:36 PM
If you check serial number and it’s 16306078 and above it should have clock and wake up alarm facility. Information from Beoworld some time back,that I copied for my own information. I can’t find the actual web archive page as not at home.
Page 1 of 1 (7 items) | RSS
