Hello,
I am trying to get my Beocord 7000 up and running but have faced a problem that I can't solve. I have ordered new belts from Dillen and when I started the work changing them, suddenly a little spring fell out of the mechanism. In the attached picture you can see the spring, where I assume it should be fitted, but when I try to check the function it just flips on the side and jumps of. I wonder if there is something missing where I marked the red ring? Should there be something that makes the spring be on it´s place?
Hope someone can help,
Best regards
//Håkan
