B&O and HP have been a cosy couple for some time now and are taking their relationship to a new level.HP introduced a new All-in-One PC... with B&O sound(bar) and a monitor that even looks B&O-ish... The BeoVision 6 has a younger brother!Link: https://www8.hp.com/us/en/desktops/envy-32-all-in-one.html
Karel.
kuyttendaele: B&O and HP have been a cosy couple for some time now and are taking their relationship to a new level.HP introduced a new All-in-One PC... with B&O sound(bar) and a monitor that even looks B&O-ish... The BeoVision 6 has a younger brother!Link: https://www8.hp.com/us/en/desktops/envy-32-all-in-one.html Karel.
I’d like to have a listen to that.
Might be a good idea.....if you are a Windows user ;-)
P.S. Good find, Karel!
Did a little dive into the specs... The speaker can even be used when the PC(part) is turned off... I wonder where they got that idea....
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
kuyttendaele: Did a little dive into the specs... The speaker can even be used when the PC(part) is turned off... I wonder where they got that idea.... Karel.
B&O works heavily with HP.
One of the ‘listening’/test rooms - that you did not see, when you were there - is dedicated to this cooperation.....I have been told.
