Hi I am new comer to this forum, I have a Beomaster 1900 type 2903.
I keeps blowing the 2x1.6 amp fuses. I have isolated the output stage but still blowing.
Also i have the 15v line the full wave rectifiers and there are ok.
Any advice on that please?
If the rectifiers are both fine, it could be a short in the mains transfomer.
Thanks Martin for your reply, I thought that might be the mains transformer. Are they available you think, if so do you a price for it?
Savvas
Depends on the Beomaster being a european (domestic) or US (export) version.The european version has the rotary voltage selector at the bottom. The export version is factory set for one voltage.I don't have the US version, but I may be able to find a european transformer.For parts please email or PM me.
It is the european version because has the the rotary voltage selector at the bottom.
How much would it be for the european version?
