Anybody point me in the direction of where the wires are soldered in the DIN plug? Dying to see if a resoldered plug solves my issues. thanks
https://www.beoworld.org/beotech/index.htm
https://www.beoworld.org/beotech/misc1.htm
I looked at this but colours don’t match the colours in my cable. I have red white yellow blue black brown and a ground ???
Hello,
only the standard cables MASTERLINK (8-pin) and DATALINK (7-pin) are described on the BEOTECH side!
The beogram connection cable is somewhat differentiated
please have a look at the thread
https://archivedforum2.beoworld.org/forums/p/39007/297772.aspx#297772
there I described the connector of the Beogram
the thread is partly in german, but google is a good friend here (translator)!
wilfried
I took the DIN from the cd apart and copied wiring - bingo, worked a treat. thanks for taking the time to help reply. derek.
