After I select my BLGW in the BeoLink menu on the Eclipse, I select Home Control on my BR One. It then asks me to add user and password. However, the cursor starts on password, and I can’t find a way to move the cursor to User, so that I can enter the admin username. Seems like a silly question, but rather stuck here
I found a solution to this, but talk about poor UI design: by using the touch pad remote on my iPhone B&O app I was able to position the cursor on the User field, followed by the Password field. This cannot be done using BeoRemote One!
Anyway: I managed to enter the details, and Eclipse is now connected to BLGW.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Thanks - that's what I also eventually did (use the phone app). I just find it incredibly lacking that you can't enter the details with the BeoRemote One only. But now I know. Thanks again
