Beocenter 1 Distorted Picture
This post has 1 Reply | 0 Followers
Maurice
Posts 108
Maurice Posted: Mon, Aug 26 2013 6:59 PM
Hi beo guys and gals
I have recently been given a BC1 with the following problem. The set starts up with a beautiful sound & picture on either stb or the built in DVD, however on any picture input it  has a pinching in of the picture at the top and bottom both sides  eg slight horizontal symmetrical contraction and in the mid  hight a pronounced inward curvature. The fault happens if I gently tap the contrast screen and if i even touch the gegauss cable. I have tried to induce the fault by gentle mechanical tapping on PCB4 to no avail Having researched this fault It appears to be a pincushion fault  but the degauss cable defiantly reproduces the fault.  with no schematic on this site avail I am stuck if anyone can it would be greatly appreciated.
regards Maurice
wisepass
Posts 2
wisepass replied on Fri, Jan 10 2020 8:04 PM
Did you ever solve this Maurice? I have a similar problem
Page 1 of 1 (2 items) | RSS
