Hi there,
I got this old Beolit 562H532.
It is in good visual shape but the handle is missing a screw.
Someone's been trying to repair it before me so it is not working but all parts are included. It needs to be assembled and recapped.
I would like to know if this item is of any real value or just "nice to have". See pictures below.
Kind Regards,
Christian Leicht
https://leicht.io - B&O Custom Parts & 3D Models
Hello!
At antique shops in DK they are for sale at 1000 + DKK, ... in working order.
Best regards, Hans
And I just got hold of one like it .
It is in general good working order, except the LW band does not work, but that ought to be simple to fix. And maybe et needs a couple of new capacitors, just for perfection. Also, the battery box has one spring missing and some others badly corroded (leaking batteries ), but I have installed a clip for a 9 volt battery. Saves you buying 150,- dkk worth of D batteries, and as the radio draws less than 20 mA, a modern 9 volt battery will last adequately.
I also have a 562 H 535 model. It has an extra SW band and the tone switch is a pull switch in the volume pot.
