Hello,A Beogram 3000 type 5228 turntable from a friend nolonger works with the motor engine blocked and speedselector out of service because part marked 212(PN#2905032) on the service manual is missing.Where can I find this element or if it's impossible to get one, who can send me a detailed diagram of this part(with dimensions) to try to rebuild one with a 3D printer for example.Then I will try to restore the motor.
Thanks for your help.
