Wanting to sell on Ebay?
AaronS
Posts 1
AaronS Posted: Wed, Mar 17 2021 10:40 PM
Hi All,
I've just bought a house in Adelaide, SA. It is completely decked out with BeoVision10/40, BeoMaster5, BeoSound5, plus multi-room speakers.
I'm wanting to sell it on Ebay. Is it rude to ask whoever is doing the local pickup only to do the removal also? Or should I attempt to remove it all myself first? I'm not the worlds biggest fan of Ebay... Could try Gumtree also, but I'm not keen on letting all and sundry wander through my house...
Thanks!
loureed5
Posts 171
loureed5 replied on Fri, Mar 19 2021 2:38 PM
Firstly I wouldn't want the removal done by the buyers-recipe for disaster!
So if you think you could remove them yourself, that would be the best I think.
I see you're in Adelaide,and there is a dealer in Norwood called "Bang and Olufsen Adelaide".
If you're not confident to remove yourself, maybe worth a phone call to them,to see if one of their technicians can do it at a reasonable price,
Who knows? they might be interested in buying some of it ,and you wouldn't need to be at the mercy of E-Bay and Gumtree,
regards
Noel.
Page 1 of 1 (2 items) | RSS
DigiCert Secured Site Seal
