beosystem 4 - motorstand
This post has 1 Reply | 2 Followers
beoandy
sissi not kangaroo
Posts 329
beoandy Posted: Mon, Feb 3 2020 7:48 PM
i plan to change the beosystem 3 on a beovision 9 to a beosystem 4.
powerlink adapter, the monitor and the ir/auto contrast wiring doesn’t seem to be the problem. (found the cabling in the service manual)
but the beovision 9/beosystem 3 has a old motorstand with 5 pins:
1 - GND (Yellow)
2 - Turn L (Red)
3 - Turn R (Brown)
4 - Pos (Black)
5 - +12 (Orange)
and the beosystem 4 has 4 pins with can-bus:
MicroFit 4-pin
Pin 1 - CANL_C Negative CAN bus signal
Pin 2 - GND_STAND Ground for stand
Pin 3 - CANH_C Positive CAN bus signal
Pin 4 - 12V_STAND_C 12V supply for standTMDS.
is there any chance to control the old stand of the bv9 with the 4 pin can-bus of the beosystem 4? a adapter? or maybe change the motor and control of the bv9 stand with motor/control of a newer stand (bv11)?
thanks beoandy
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
DMacri
United States
Posts 881
DMacri replied on Fri, Feb 7 2020 1:20 PM
It seems that they may be operating with different control standards. The new setup appears to be using CAN bus for control.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Page 1 of 1 (2 items) | RSS
