Change the AM to FM by Beolink on Beomaster 6500
This post has 3 Replies | 0 Followers
Pavel
Posts 5
Pavel Posted: Tue, Nov 3 2020 4:02 PM
Hello,
How can I change the AM to FM on my Beomaster 6500 with Beolink (without TURN button), the shift + sound doesn't work.
thanks
Pavel
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Nov 3 2020 5:33 PM
It should be SHIFT then SOUND, you don't press them together.
Pavel
Posts 5
Pavel replied on Thu, Nov 5 2020 1:05 PM
Thank you very much. It works, but Beomaster doesn't start to tune. I have Fm room antenna connected.
Pavel
trackbeo
Posts 644
Pavel:
If you mean "start" literally, then to begin scan/search-ing, you press > (or <) after pressing GOTO, on a Beolink 1000.  (GOTO also allows you to press 0-9 buttons to tune frequencies manually, rather than the presets you would normally get with 0-9 buttons.)
Page 1 of 1 (4 items) | RSS
