Hello,
When I want to check the battery state I press Stand By and the center button and select the corresponding option on the screen. So far so good. But how can I prevent shutting down my TV, when I want to check during watching TV.
I skip into the initial screen, where I can select a zone. But as soon as i press Stand By and the center button of ny Beo6, it also send a stand by ir command. What can I do to stop sending the IR stand by command.
thanks
alexsunny
I've just checked mine as I made up a new battery pack the other week, I just went into the kitchen, the battery indicator is full red, Sorted
alexsunny123:When I want to check the battery state
Why bother? A Beo6 battery is ALWAYS low!
