Then: I have 10-11 zones with old masterlink product but RJ45 cable through the house. Light commandos always worked fine. Nearly 100%.
Now: I switched to Beolink Gateway, also added some new product. In Livingroom i kept my Beovision 7-55 however, the light commando worked fine from beginning. Then they don´t. I restarted Beolink Gateway and it worked fine again, then after a while it don´t.. Now it never works..
Looks like there is something in new netlink that take this function away.. Very frustrating, but cannot find anything wrong in the installation.
Any ideas?
This is strange...
The only difference between MLGW and BLGW concerning light/control commands is, that MLGW can send state to Masterlink, which the BLGW can not
So, if the BV7-55 is the videomaster, I`d try to set the `STAT. TO MLGW OFF`- you will find the setting in the customer service menu of your BV7.
It´s just a guess, maybe it won`t help (?)
Good Luck
Stefan
