Hello
i have a problem with BeoRemote One and LG C9.
when I change from live tv-on remote- to Apple it changes source perfect. However ATV4K is only controlled after I press List-living room and then press Home Cinema. First then I can control my ATV4K.
shouldent the remote just jump right on to being controlled. So I really need to pres list etc..
setup is LGC9-Beoaound stage- Beoremote one.
it works if I connect Apple TV directly to stage HDMI 2, however then it takes about 20 seconds to start up
So you have Apple TV 4K to LG C9 via HDMI and HDMI ARC to Stage. I don’t have the beo remote, but have Apple TV 4K connected to both a Sony and LG TVs - in both cases when the TV switches to Apple TV on screen I can use the native remotes or Apple TV remotes to control the Apple TV. Even works with my Stage. I prefer using the Apple TV remote since I don’t have Live TV - my Live TV comes through an Apple TV App which has all my cable and local broadcasters. I am assuming if the LG and Sony remotes work, so should the Beoremote One. Remember on the LG to have the HDMI CEC setting (Simlink or something in menu) turned to on. In my case the default was set to off.
B&O in my life 😊:
