Beolab 14 + Connection hub
This post has 0 Replies | 0 Followers
GunnarE
Posts 3
GunnarE Posted: Thu, Feb 20 2020 4:25 PM
Hey guys,
Just set up a Beolab 14 system with the connection hub in my apartment. Sound is coming through clear so the speakers are in good shape but the connection hub is playing with me a bit. I have the hub connected to my old LG TV via toslink and then I have an apple tv connected to the TV via hdmi.
I use the Apple tv remote for everything and I have went through the IR setup on the hub to "teach" it the volume up/down/mute functions.
The problem is that the hub increases and decreases volume without me doing anything - I can see the light on the hub flashing and then the volume goes up or down without me touching the remote.
Has anyone else had this problem?
Cheers,
Gunnar
p.s. Image attached for fun - I know the tv is a bit off centre, I will replace it soon so could not be bothered changing it ;)
Page 1 of 1 (1 items) | RSS
DigiCert Secured Site Seal
