Beogram 1500 type 5230 motor adjustment HELP
This post has 0 Replies | 0 Followers
JensP
Posts 2
JensP Posted: Wed, Feb 26 2020 8:35 PM
Hello everyone and thank you for a great forum! I have had the pleasure of inheriting my mothers Beogram 1500 from here in Denmark and I'm currently restoring it.
So far I have completely disassembled it and corrected some flaws and afterwards I have put everything back together again. Everything works and  it is cleaned, fixed etc. but I have a few questions I thought youtthclever people could help me with 😊
The rubber wheel engaged by the motor spinning, seems to be running fairly irregular 🤔
I have cleaned and lubed everything and it Is running but I am unsure if It running correctly.
1: Is it normal to have some speed-selection issues on the 1500?
2: Is there a certain way to set up the motor in relevance to the rubber wheel that is engaged? (I am able to move the arm supporting it)
3: What is the point of/how do I adjust the so called "Vernier" wire, wheel and shaft?
I hope you guys can help, so thank you in advance! The pictures look weird - sorry about that (file sizes on a modern phone is apparently too high😛)
Page 1 of 1 (1 items) | RSS
