Question for any 7700 owners, the manual states that the back panel tilts up
to access the speaker connections etc, I’m having difficulty with it as it moves
a few mm then it seeems something is stopping it moving any further, I don’t want to
force it in case I break something, is it normal to feel some resistance?
It has a catch (bronze spring plate).Pull a little harder.
Thanks will give it a try
