Installed hdmi modulator, so we can watch sky hd, on freeview on our bang and olufsen tvs, which consist 2 x beocemtre 6-26 1 x bevision 7 and 1 x beovision 11, i can get freeview but can get the sky hd all i get is sound, apart from bvis 11 im guessing the tv's are just to old?
Which TV is the master? It should work as I've had Apple TV connected to a BV8 via an HDMI to RGB connector and the onto a BV6-26
Hi, its bvis 732 which is the master. System is slightly different as we have all the kit in the cupboard, all works great including freeview, what we wanted to do use the hdmi modulator with apple tv connected then it can be watched as one of the freeview channels, as i said great sound but no picture, with your solution, will tjis be able to feed to all the tvs with better picture
