Hi There,
I have got a B&O MPAV9000 (BEOCENTER 2300). It usually has been sold together with the BEOVISION 9000 as a BEOsystem. If you want to use eg the CDplayer of the MPAVthen you have to do it via the TV BEOVISION 9000 and from there tot a amplifier. But I don't have the BEOVISION 9000 anymore, and I can't use the MAPV anymore. But there should be a possibility to connect the MPAV9000 directly to a non B&O amplifier via the B&O Multilink cable to RCA connectors.
Can somebody tell or help me out with this?
Thanks in advance for your help!
I think we have been here before in the past!
If you have a MP9000 rather than a BC2300,
I believe it has various bits missing that are in the AV9000 - The ML circuits are in the TV and I seem to remember that there is an issue with the volume control. Worth looking in the old archive for this but I believe the consensus was that although it is possible to do something with these panels, it is expensive and as a 2300 is available for so little money now, it was not an economical solution. What connections are there on your MP9000 - I guess only the ML cable.
Peter
