How to check if a stylus has been used or not
fkatze
Posts 92
fkatze Posted: Sat, Mar 21 2020 4:51 AM
Amongst a bunch of stuff I bought a couple of months ago, there was a small packet that includes a stylus which I think is for the Beocentre 3500.  It looks like it might have been bought as a spare, but never used.  Is there a way to tell?
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Mar 21 2020 7:07 AM
If you don’t have a microscope to inspect the tip, you can tell by listening. Usually a dull sound, with recessed treble, means that the diamond tip is worn out.
Jacques
fkatze
Posts 92
fkatze replied on Sat, Mar 21 2020 5:27 PM
Thanks for yourr reply.
ok, so visual inspection should be able to tell me.  Is there a reference image anywhere of what it should look like?
Page 1 of 1 (3 items) | RSS
