Hi all,
This week I picked up a BV7-32 to replace the BV6-26 in the bedroom. It works OK but makes a lot of noise! I thought the noise came from the fans, but when I blocked them from moving (the TV said 'fan error') the noise was still there? It is quite annoying.
Do you think this is is a common phenomenon for this TV? And is there a fix?
Thanks for letting know!
Johan
