Hello.
I would kindly appreciate if someone could give me a hinch, how to open the front side of the TV-remove the glass pannel so it would be possible to clean it from the back side. I have bougth this second hand TV recently and it has some kind of smudges on the inner side of tge glass.
Another problem i have is with motorised floor stand. I have no idea how to test it and make it work. I have pluged it in before conecting the TV to mains, sadly it does not work. Any common problems or solutuons when it does not want to turn? I also cannot bring it to TV menu via Beo4 from the list function.
Thank you and kind regards, Gašper
gapy100:how to open the front side of the TV-remove the glass pannel
