Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Thousand times Thank you for uploading it. Such a pleasure of seeing any B&O brochure or catalogue…
Thank you, Thank you, Thank you!
I have quite a few UK brochures from years ago, I'd need to check the garage.
TEL
It's really a beautiful catalog: good mix of customers stories with beautiful setups where you almost need to search the B&O product and gorgeous studio shots from iconic products from that era. You're lucky, must be something to have it in real.
From the catalogues I have (unfortunately in PDF), they did the same in the 1997 catalog. In later catalogues it was done differently by showing more empty spaces, room, apartments, but with some little exceptions, no people (Masa Kajimoto with Beosound 9000, Beolabs 5 and is sportscar in the 2005 catalog, which is one of my favorites with those pictures from old products and new reinterpretation side by side).
I have compiled all the pictures of seethroughyou in a PDF to enjoy the beauty of the doubles spreadsheets but I get an error message when adding it, maybe because it's to heavy? I've have managed to reduce it to 4,3 megs while keeping it readable. If anyone has a solution I would be happy to share the pdf.
What a fantastic catalogue! I have a few older B&O brochures (my favourite is the 1990 one shot in Le Corbusier's "Villa Turque" featuring the old Beosystems).
Could I please ask if any Beoworlders in the UK have got a paper version of this year 2000 catalogue that I could borrow for a couple of weeks? It is for an upcoming YouTube video. I will of course return it in good condition and include some free cables of your choice if that helps!
Thanks, Steve.
Steve.
www.soundsheavenly.com
Here you can buy from a german ebay seller your own catalogue in german speaking.
https://www.ebay.de/itm/Bang-Olufsen-Radio-HIFI-Katalog-1999-96-Seiten-aus-1-Hand/283645254921?hash=item420a931d09:g:6u4AAOSwHwJdpzFK
... and here are a lot of more catalogues
https://www.ebay.de/sch/i.html?_from=R40&_trksid=p2505460.m570.l1311.R1.TR4.TRC2.A0.H0.Xbeoremote.TRS0&_nkw=bang+olufsen+katalog&_sacat=0
good luck
matador43:If anyone has a solution I would be happy to share the pdf.
Hi CB,
I have, but I'm constantly using them and clearing them again, so it won't be a reliable solution.
Thanks guys,
I would ideally need to find a paper copy in English within the next week or so, posting from Germany might take a little longer at the moment....
Kind regards, Steve
Many thanks, yes that would be perfect please! Please can you drop me a quick email at steve@soundsheavenly.com or send me a PM via BeoWorld with your delivery postcode so I can locate your cable order?
I can then include an SAE for you to post out the catalogue. Would you like me to also send you an extra B&O catalogue from the early 2000s as a gift when I return your catalogue in a week or so?
Kind regards, Steve.
Steve at Sounds Heavenly:Hi, Many thanks, yes that would be perfect please! Please can you drop me a quick email at steve@soundsheavenly.com or send me a PM via BeoWorld with your delivery postcode so I can locate your cable order? I can then include an SAE for you to post out the catalogue. Would you like me to also send you an extra B&O catalogue from the early 2000s as a gift when I return your catalogue in a week or so? Kind regards, Steve. Steve. www.soundsheavenly.com Sounds Heavenly are proud to sponsor BeoWorld!
Thanks!
I will get the postage paid envelope sent out on Monday, then the catalogue will be back with you in a week or so.
As soon as my channel gets to 2000 subscribers, I will upload the video here: https://www.youtube.com/soundsheavenlycables
