Beo4 join command from Essence Remote
This post has 3 Replies | 2 Followers
Kelwin
Cambridge
Posts 13
Kelwin Posted: Sun, Apr 5 2020 10:27 AM
I have installed an essence remote next to my Beovision 11. Is it true that you can't get the remote into a mode where it sends the Beo4 join command?
The table on the FAQ indicate so, but I thought that the primary purpose of the Essence remote was to be able to join.
Does anyone have a way to make the Beovision 11 joining an existing audio stream?
lawrencejmcook
Posts 742
Hi Kelwin,
The top “button” of the Essence remote is “Join”; looks like an empty (CORRECTED) circle.
Lawrence
Millemissen
Flensborg, Denmark
Posts 14,680
Did you put the Essence Remote In Mode 7?
beojeff
USA
Posts 2,012
beojeff replied on Tue, Apr 7 2020 12:59 AM
Millemissen:
I use an Essence remote in mode 7 with my BeoSystem 4. Pressing the top button does not sent a JOIN command. It only works with a source that has been assigned to react to the MUSIC button via programming of that source on the BeoSystem 4.
Page 1 of 1 (4 items) | RSS
