I need your help ;-) Just want to know which serial of BeoVision 7-40 means which MK ?
Further I want to know the differences between the MKs - the original website isn´t very helpfull.
Thanks / Kind Regards
Thomas
Thanks for the input - but the seller resides on ebay and just posted the sn. He will be able to check for the type upcoming weekend :(
Btw: Is there a chance to upgrade the DVD Player to an Blue Ray-Player ?
Further Update: it will be type 9331 incl. Sat Receiver - will this be HD ?
Salut,
J'ai besoin de votre aide , le miens est un 9364 que pensey vous du type ? merci
super merci , mais je suis en France quel demo TNT me conseillez vous ?
SUPER merci , quel démodulateur pour la France me conseillez vous ?
Hi would anyone know if there’s a full listing by all types.. I’m specifically interested in Series 3,4,5,6 since these were the ones with theBeosystem3
i saw a type 9645 for sale and it has blue ray which puts it likely as a type 4,5 or 6... but having troubles tracking it down further..
any help would be appreciated please
AFAIK:
BeoVision 7-40 have the following type numbers:MK I : 9351-9359MK II : 9361-9369MK III: 9370-9384, 9398MK IV 9440MK V ( Type # 9641-9657MK VI (Type # 7741-7757)BV7-40 Mk1: Ist nicht HD tauglich (Ist das HD Ready Kit nachgerüstet worden ist er wie Mk2)BV7-40 Mk2: Änderung zu Mk1: Ist HD ready über DVI (neuer Scaler, neue Software)BV7-40 Mk3: Änderung zu Mk2: Full HD, neue Elektronik (System3), HDMI AnschlüsseBV7-40 Mk4: Änderung zu Mk3: Blu-ray Player, 100Hz PanelBV7-40 Mk5: Änderung zu Mk4: 200Hz PanelBV7-40 Mk6: Änderung zu Mk5: 3D****************************************BV7-32Mark I 9310 - 9320Mark II 9321 - 9329Mark III 9331 - 9339, 9341 - 9350, 9399Mark IV 9171 - 9180Mark V 9181 - 9190
