Recently purchased a used Overture 2500. It works fine except tape recorder needs new drive belt, but that is a different story.My probelem:it has a starnge habit of switching on without anyone touching it. And nobody is touching the remote.When I say switch on, I mean the lights go on, but no sound comes out of the speakers. Sometimes the CD starts spinning, but still no sound.It can happen when I´m alone in the house, so no other remotes in use. Nearest neighbour is 20-30 meters away, so not their remotes?It sits on the wall in the kitchen. Interference from some other electronics? Fridge/freezer?
if you see a green light next to the red standby light (on the display) it indicates that a timer has been set. With the unit in Standby, press the mute button to cancel it and the green light should go off.
Timer! You´re right. Mystery solved. Had to go into the menu and delete the timer settings one by one.Thank you for the suggestion. I would never have figured out on my own. Didn´t even know there was a timer built in.
