Beomaster 2400 four speaker switch broken
This post has 6 Replies | 0 Followers
Mark2020
Posts 12
Mark2020 Posted: Thu, Apr 23 2020 2:06 AM
Hi. This happened suddenly, right after finally setting up my rear speakers so I'm freaking out a bit. I set the switch from "off" to "2" and a loud pop occurred. Then the switch was swinging back and forth loosely. I took the amp out and flipped it and could see the physical switch in the hole was also swinging freely and not locking on either side. Taking the bottom off the unit verified this. I can see the switch moving the connectors a bit, but I can get to it to see what's wrong. Obviously something broke as the front speakers work fine, but the back don't. Is there a fix for this?
Alternatively, would it be possible to splice two speakers into one channel, or would that be too much for the amp to handle?
sonavor
Texas, United States
Posts 3,732
sonavor replied on Thu, Apr 23 2020 2:59 AM
That switch sits very close to the output amplifier rail voltage reservoirs (the two large, gray capacitors there). I would guess that something got too close and made contact where it shouldn't. It is also possible that the speaker wiring got crossed and something shorted regarding those. It shouldn't be too difficult to find a replacement rear speaker switch but you will need to carefully review all of that wiring.
-sonavor
Mark2020
Posts 12
Mark2020 replied on Thu, Apr 23 2020 3:50 AM
I don't think it's a short. I think the switch is physically broken, hence the slipping back and forth with no resistance.
Mark2020
Posts 12
Mark2020
Posts 12
Mark2020 replied on Thu, Apr 23 2020 3:51 AM
sonavor
Posts 3,732
sonavor replied on Thu, Apr 23 2020 6:59 AM
I see.  It wasn't a pop with a flash and some burning.  It is just that the switch is loose and making/breaking connections to the speaker. You are describing the pop or thump one hears with from speakers when power is suddenly removed or applied without any muting.
That switch should be easy to find a replacement for.
-sonavor
Mark2020
Posts 12
Mark2020 replied on Thu, Apr 23 2020 4:45 PM
Actually, it was a physical pop. Like plastic snapping. It didn't come from the speakers.
Page 1 of 1 (7 items) | RSS
