beopaul:Do any of the newer video products such as the BeoSystem 4 support AST? I don't see it mentioned any more. It also seems the discontinuation of the Beo6 would make it difficult to change listening positions. -- Paul
-- Paul
Hi Paul,
The AST algorithm is not included in the the BeoSystem 4 (or BeoPlay V1, BeoVisions 11 and Avant). However, these products all allow for you to create up to 9 different "Speaker Groups", each of which can have it own:
Once these have been created for your listening positions and/or requirements (i.e. 2.0 vs. 5.1 listening in the same listening position) then you can switch between Speaker Groups in a number of different ways on different remotes. For example, on the Beo4, the two fastest ways are
Hope this helps.
Cheers
-geoff
I’m trying to get my beo4 to list speaker group s but it won’t show any, do you know why?
Also can you use the ast with a beo5 instead of 6 thanks
