I can go into Eclipse sound settings and adjust the default volume setting. I assumed that it would be the same default volume when I went into the Apple TV attached to it. But it isn’t. Is there a way of adjusting the default sound setting on Apple TV?
Yes, I have set up MyButtons set up for Apple TV already. In the sound section of the Eclipse settings, I have set the default volume to 60, and I assumed it would apply to everything attached to the Eclipse, but the default volume on ATV comes on at 55. I’ve been in to ATV settings and cannot see a volume control to adjust The volume to 60 as well. Am I looking in the wrong place?
Worked a treat! Thanks very much
As you’ve been so helpful, could I ask you something else? When I first got this system, I adjusted the Eclipse picture settings, but I seem to remember I tweaked the picture settings for ATV alone. Did I remember correctly, or do the Eclipse picture settings adjust ATV picture settings as well?
Thanks again
Hi
Any thoughts on this?
Brilliant! Thanks so much
