Hi all,
Ive recently acquired a pair of S50's and can't really find much info on them other then that they were only produced for 1 year.
Are they any good as far as a small 50watt speaker goes? Any info on the design, crossovers etc?
http://www.beoworld.org/prod_details.asp?pid=668
Yes, it is a very nice speaker in its own right. One you don't get tired of listening to.
What do you want to know about the design and crossovers ?
Just a bit more product info really from B&O. I downloaded the user guide which helped a bit.
Cheers
Hi Cooker,
I got my hands on my families old S50 speakers.
They need some TLC .
Could you provide me the user guide you mentioned?
I cant find it and I would like to know what parts I need to order to repair them (foam rings - capacitor...)
Tks
Yanick
The user guide won't tell you any of that.
Foam rings - No exact match rings can be found anywhere, - measure and find what you can that comes closest.
A capacitor kit is readily available. PM or email me.
memoji iphone 6
animoji
iphone memoji
memoji for Android
if you want apk directly to your android click the links.
