I am looking for a XML file for my Beo5 that is for a Samsung LCD tv none Smart. Basically on/off, volume, Digital tv guide and channels up and down.
Thanks.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
There are several possible standard TV combinations and I have attached the one which I think is likely to be most suitable for you.
Regards Keith....
