Beovox CX100 Plastic Speaker Grill Repair / Replacement
This post has 7 Replies | 2 Followers
noise
Posts 7
noise Posted: Sat, Apr 25 2020 8:03 AM
I have a set of white CX100's that have broken tabs on the woofer grills. The larger middle tab and smaller tab are broken. Also, one of them has a broken thin cross-member going to a front corner. Is there a way to fix these features of the frames, or are there factory replacements available?
Ravsted
Denmark
Posts 345
Ravsted replied on Sat, Apr 25 2020 10:40 PM
What about 3D printing?
Guess these are the files you need.
Maybe you know someone (who knows someone) who can print them for you?
Should only be a few $ of material
https://www.thingiverse.com/thing:365459
noise
Posts 7
noise replied on Fri, May 22 2020 8:21 AM
I looked into it, but it is somewhat expensive for the better quality prints and materials. The parts would probably be more brittle than the originals in a couple years.
noise
Posts 7
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, May 22 2020 8:44 AM
Black or white?
Can't you glue the broken tabs? I have done that many times.
noise
Posts 7
noise replied on Sat, May 23 2020 9:37 PM
White. Some of them are completely missing. One grill has a missing section on the thin member that forms the triangle on the side.
noise
Posts 7
Here's what it looks like.
Dillen
Posts 13,191
Dillen replied on Tue, May 26 2020 7:03 AM
The white ones always tended to become more brittle than the black.
If you fit black plastic frames behind white cloth they will shine through, but you could paint them white.
Page 1 of 1 (8 items) | RSS
