I have a 2002 BeoVision TV which I love and want to keep. I also want to use it to watch the internet. The problem is that the TV has a 21pin AV socket, not an HDMI socket or a skart socket so I need something to convert the HDMI signal from the laptop into a 21pin AV signal which I can plug into the TV. Does anyone know how I can connect it up ? I obtained an HDMI to skart converter thinking that the TV had a conventional skart socket but it obviously doesn't fit. Is there such a thing as skart to HDMI converter ? I haven't been able to find anything. All suggestions (not too technical) gratefully received. Many thanks, Andrew
