hi all, I finally have all the equipment I wanted, so I'm trying to set it up.
Situation : Beosound 9000, connected to a Beolab 2 SW, the Beolab 2 outputs are connected to Beolab 8000 pair.
Next to it is a Beovision 7-55 with a Beolab 7-6 centre speaker.
Both devices work, but now I would want to connect them with masterlink to be able to use the Beolab2 & Beolab 8000 as front speakers & suwbwoofer on the Beovision. And of course still use them as speakers whenever I play the BS.
I connected the masterlink cable to the BS & the BV (that's the easy part), but now to what V.OPT option do I set the BV 7-55 and to what A.OPT dp I set the BS 9000 ?
And how do I add the speakers to the list of speakers on the BV ?
How do I make this work ?
Should be fairly easy......after reading the user guide
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/BEOVISION%207-40%2055/beovision7-40-55_userguide_english.pdf#page58
Pages 22 and 58
The BS9000 will be in option 0 when no speakers attached there.
Video in option 1.
All controlling going through the 7-55.
thanks guys.
Sorry for late reply, I had some internet issues (and even no mobile internet, imagine ...)
I connected the BL8000 & BL2 to the Beovision, so all speakers are connected there.
Then I put the BS9000 in option 0, and TV in option 1 (if I remember well, lol), all commands indeed now go via the TV, works like a dream :)Took a bit of time to find out how HDMI inputs work etc, but once you know ... ;)Now I have to find out how to remove unwanted items from my Beo4 list menu :)
Everything in standby!
Push List and the red (standby) dot at the same time - then let loose.
Looking at the display and pushing List several time takes you to the wanted action.
And so on.
thank you, will try asap :)
