Just bought a set of Beolab 8000’s and I am super pleased with them 😊
However at some frequencies the tweeter crackels a bit. Is this usually something that can be fixed by cleaning/maintaining something within the connections and or amplifiers, or is it a dead tweeter?
If it’s dead, where do I source a replacement that has the correct spec?
