Trouble removing Essence remote to change battery
This post has 4 Replies | 0 Followers
Barry Santini
New York
Posts 543
Barry Santini Posted: Sun, Jun 14 2020 8:52 PM
I have an Essence remote mounted on a desktop plate. I can’t seem to “pull off” the remote from the wall plate in order to change the batteries.
Any advice?
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Sun, Jun 14 2020 9:33 PM
You have to slide it off the back plate
lawrencejmcook
Posts 742
To build on Fansastic’s answer, if the Essence is sitting on the table so you can read the “bang & olufsen”, slide it away from you toward the twelve o’clock position.
Lawrence
Barry Santini
New York
Posts 543
Thank you guys. That helped
B
lawrencejmcook
Posts 742
I like your posts, Barry. Very succinct and practical. Glad to be able to help in a small way.
Page 1 of 1 (5 items) | RSS
