Upgrade wiring on a Beogram 4002 to CD4 capabilities.
Struer
London
Posts 106
Struer Posted: Sun, Jun 14 2020 8:18 PM
Hi all,
 I am looking to convert a 4002 type 514 to be capable of playing SQ / quadrophonic records.
The main capacitor has extra connections and the deck has the switch hole and two screw holes on the right hand side of the chassis. I am awaiting a donor Beogram CD4 board. The deck is wired with a Din 5 with 3 connection leads going from the Din LEAD to the and one black lead soldered as a grounding lead.
 Does the DIN 5 lead need to be replaced with another DIN 5 lead to allow the rear signal L and R speaker signals?
 Also might anyone have a mouser stock number for a suitable 47 nanofarad capacitor as the 5524 which I’m working on doesn’t have one?
Page 1 of 1 (1 items) | RSS
