Hello all,
Just about to get a Beomaster 1700 to complete my basic set of B&O kit. However, it needs the volume belt replacing. Are there easy to source in the UK and replace?
Also is eBay the best place to get the converters to allow normal speaker cables to be connected to the unit?
Thanks in advance
Soody
Not in the UK, but I have this:
https://www.ebay.com/itm/Bang-Olufsen-part-Beomaster-1600-1700-caterpillar-band-tonecontrol-belt/254612367568?hash=item3b481468d0:g:WyQAAOSw6~de0lLr
Easy to replace? Err.. it could've been worse, but it's more of a half-hour job than a 2-minute one.
Hi Martin, thanks for the reply. Now I know I can get the part, I will arrange to buy the unit. Once I have it I will bein touch.
Regards
