Reassembling the friction plate and the damper arm on beocenter 7007
This post has 11 Replies | 0 Followers
taradict
Paris, France
Posts 14
taradict Posted: Sun, May 10 2020 4:37 PM
I have removed the metal cover of my beocenter 7007 for cleaning
But unfortunately, I can't reassemble the friction plate with the damper arm and the large spring, there is also a little part  named slider on service manual...
I don't understand how it works...
Thanks for your help
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, May 10 2020 5:12 PM
The damper plate (the black plastic part in the photo) fits into a ridge at the underside of the large alu lid.
At the side of the "neck" of the damper plate is another "ridge", more square in shape, where the small glider (a small plastic part about 4mm long) rides up and down when the lid is opened and closed, carrying the curved end of the torsion spring - the glider has a curved indentation to suit this.
The other end of the spring is held behind a protruding plastic "nose" at the Beocenters chassis (put the other parts together first and fit
the end of the spring behind the plastic nose as the last thing).
The glider (not shown in your photo but can be seen here: https://beoparts.com/2015/06/27/slider-for-lid-damper-plate-3035027/)
should ride in Kilopoise grease, - same stuff as is used between the damper plate and the friction plate.
Missing the glider? Look down beside the transformer. When it falls out it usually gets caught in the greasy stuff that has dripped down there.
taradict
Paris, France
Posts 14
taradict replied on Sun, May 10 2020 5:36 PM
Thanks Dillen, I have the glider... I will read your answer with attention to fix my problem. Many thanks as usual.
taradict
Paris, France
Posts 14
taradict replied on Sun, May 10 2020 8:05 PM
At the end, the assembly should look like this? I have not put the glider on the assembly...
Dillen
Posts 13,191
Dillen replied on Sun, May 10 2020 9:01 PM
The spring is upside down.
And it should rest its curved part on the glider - not its pointy end.
taradict
Paris, France
Posts 14
taradict replied on Mon, May 11 2020 12:19 AM
when I removed the metal lid, the spring has jump with the slider/glider... So I imagine, I have to force when i will put back the spring...
taradict
Paris, France
Posts 14
taradict replied on Mon, May 11 2020 9:45 PM
Hi Martin,
Like this ? Thanks
Dillen
Posts 13,191
Dillen replied on Mon, May 11 2020 10:15 PM
Yes, and you can see inside the Beocenter, that the other end of the spring goes behind a "nose" cast into the plastic chassis.
And the spring is held in place by a metal bracket with two screws.
Fit it all together before locking/forcing the spring in behind the "nose".
taradict
Paris, France
Posts 14
taradict replied on Mon, May 11 2020 10:29 PM
Thanks ! now i wait for my new plate ordered on ebay... Got my order? Thanks.
Yes, for the other end of the spring i see where to block it,  so I have to twist it 90°, right ?
Ellison1604
Posts 22
Sorry if it’s not relevant but very new to the forum and I need a new lock/catch for the control lid, any ideas or help will be really appreciated
thanks
Ellison1604
Posts 22
thanks
Chris
Newcastle, Australia.
Posts 12
Chris replied on Sat, Jun 27 2020 4:21 AM
 I used this tool to push tension on the spring to get it over the nose and into position. worked a treat.
Page 1 of 1 (12 items) | RSS
