Alarms on play products - Touch to join function?
This post has 6 Replies | 0 Followers
Jensm1996
Posts 24
Jensm1996 Posted: Sat, Jun 27 2020 9:37 AM
Hi guys,
I have a house full of BeoSound/BeoPlay products (BS1, BS2, Stage, Shape, A9, M5, M3) and i usually use alarm to my Shape in my living room, M5 in the bathroom and stage in the walkin etc.
I have set all the alarms to start on a specific radio station at 08.00, but none of the speakers plays the same, they all have different delays (1-2 seconds from eachother) i guess that's because of the buffer time on each product. (Their all cabled to the internet).
So i recently just used my Shape as an alarm and none of the others..
My question is; Is it possible to fix this delay?
Another question: Why isn't there an alarm function called "touch to join" so i can start up my radio stations and let the other touch to join or something like that?
Example; Spotify connect on a product, and let the users join so i get the multiroom effect.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sat, Jun 27 2020 11:17 AM
Jensm1996:
Only a multiroom feature can ensure proper synchronisation between devices. Unfortunately B&O does not have a group concept where you could program an alarm on one device and join others to it programmatically.
Not sure I understand the second question, but in my case I have an alarm set in my bedroom on a particular radio and I touch to join my other products as I walk in the room they are located into. Spotify cannot participate to a Beolink multiroom, all other music sources can (TuneIn, Deezer, DLNA,
Airplay or any source attached to a product line In assuming you have preserved the line in delay)
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Jun 27 2020 12:18 PM
mbolo01:
A Beolink Gateway or Beoliving can be programmed to JOIN after starting another device.
But adding the JOIN command to the Alarms would be a nice feature.
Nietz
Posts 16
Nietz replied on Mon, Jun 29 2020 10:02 PM
Carolpa:
mbolo01:
Hi
What's the command to 'JOIN' in BeoLink Gateway?
Cheers,
   Urs.
Nietz
Posts 16
Nietz
Posts 16
PaulGiles
Posts 218
PaulGiles replied on Tue, Jun 30 2020 6:19 AM
Yes, same here. M3 stars on radio, walk into kitchen and touch M5 to join.
Selecting other rooms for alarms is a Sonos feature and would be great if B&O implemented it too.
Page 1 of 1 (7 items) | RSS
