Spraying beosound 1 grill
This post has 10 Replies | 2 Followers
Mdjolly1973
Posts 51
Mdjolly1973 Posted: Mon, Nov 12 2012 5:35 PM
Hi
I have a black beosound 1 of which i want to freshen up a bit and have it sprayed white in a bodyshop,however the bodyshop is saying the grill 'holes' are too small and the paint will congeal....anyone done this before that can offer help/advice?
Cheers
Mark
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Mon, Nov 12 2012 7:24 PM
The paint will fill the holes and it'll look awful.
I'd respectfully listen to the advice of a professional body shop !!
Lee
:0)
Mdjolly1973
Posts 51
Yeh i know ur right-i wasnt sure if u could get 'thin' spraypaint that wouldnt fill the holes-oh well i never liked white really lol !
Rivenflush
Gothenburg
Posts 333
I guess one thing you could do is to cover it with some speaker cloth.
Another thing would be to insert toothpicks in al holes before you spray it - tedious but should work
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
Evan
USA
Posts 3,621
Evan replied on Mon, Nov 12 2012 8:00 PM
If you have it powder coated the holes won't get filled in. However, to have a successful powder coating, the old paint must be stripped.
Powder coat is much more durable than paint, I highly recommend it on metal parts.
Beo4 'til I die!
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Mon, Nov 12 2012 8:01 PM
Rivenflush:
Then you'd still have the black anodising in all the holes, and the paint would congeal around the toothpicks. Upon removing said toothpicks, you'd probably take chunks of paint with them too, which would look awful..
The best you can do would be to simply put a 'dust coat' on with a hand held aerosol in a few different colours to make black the background and then some arty-farty swirls or such like to liven it all up.
Lee
Smile
MediaBobNY
Greenwich Village, NYC
Posts 1,106
 A very light coat wouldn't fill in the holes, and just repeat the process several times.  Or find a place that does anodization.
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Mon, Nov 12 2012 10:33 PM
MediaBobNY:
My thoughts also...
Brengen & Ophalen
SWISS_2
Posts 57
SWISS_2 replied on Mon, Nov 12 2012 10:59 PM
You might want to consider the practical merits of scrubbing the idea in favour of buying another BS 1 screen of your colour choice online.
Compare the two costs: By the time the body shop has done it's work with time and labour, you might be looking at expenses well above the price online. And the connecting hook pins on the screen grille could be damaged, or the front grille dented, which the body shop might not warranty.
I would contact Lifestyle AV to start with. There is a fine chap there named Lee that I can vouch for.
Stoobietoo
Exeter, Devon, UK
Posts 692
Stoobietoo replied on Tue, Nov 13 2012 11:01 AM
Does anyone know how the grill / hole sizes on the BS1 differ from a Beolab 2000?
I ask because I resprayed a Beolab 2000 grilles with spray paint from a DIY store and it has come up perfect! Obviously if the holes are that much smaller on a BS1 you may struggle, but at least if you make a mistake and put the paint on too thick, you can strip it back and try again with thinner coats.
It is important to use a good primer coat as close to the finished colour you want because that sets the background and you don't need such a heavy top coats to cover.
stoobie
Orava
Finland
Posts 991
Orava replied on Tue, Nov 13 2012 5:56 PM
I'm not a painter, but if you blow air through grille right after painting doesnt it clear the holes?
Page 1 of 1 (11 items) | RSS
