Beolab 8000 to a Samsung One Connect TV
This post has 3 Replies | 0 Followers
timblaney3
Posts 2
timblaney3 Posted: Tue, Jul 14 2020 6:00 PM
The previous owner of the condo we just moved into left a pair of Beolabs 8000 installed.  I just bought a new samsung frame tv that comes with a one connect box.  Is it possible to connect the speakers to this tv?
Jaffrey2230
Washington DC
Posts 520
As long as there is a volume controlled line out, it is easy. Just get a cable and connect to the speakers and set them to line in. If TV does not have a volume controlled line out you’ll need to put a receiver in between the speakers and TV that can be volume controlled.
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
timblaney3
Posts 2
Is there an adapter for the wires?  They both have the 7pin wires?
Daniel
Svinarp, Sweden
Posts 1,632
Daniel replied on Wed, Jul 15 2020 4:34 PM
timblaney3:
Sounds like the powerlink input. Look under it, closer to the base. There you find a regular line in socket. Don’t forget to change the switch on the speaker.
Page 1 of 1 (4 items) | RSS
