Just purchased a Beosound 1 from the internet (second hand). It has a couple of issues.
1) When I place a CD in the drive - the drive opens and does not spin, does not give track listings. It sounds like it has power to it but no further luck.
2) I have programmed my Beo5 with the Beosound 1 remote and the Beosound 1 does not respond to it. It does respond to 'Radio' on my Beotime.
Type Number 2582
SW 2.4
Item Number 1860008
Serial Number 18335962
Thanks in advance for the replies.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
For some reason the Config tool software for my Beo5 defaulted to 'Transmit no IR' for the Beosound 1!
From the age of the unit, and the fact it plays radio, and knowing the product fairly well, I'd say it was the CD Mech which has failed. I'm not saying it's a common fault I see a lot of, but in 95% of cases where it won't play a CD, it's a new mech.
Sorry to hear it's playing up. Hopefully it came with some kind of guarantee?
Lee
