Hi guys,
because of the new BV11 you will find the discontinued BV10 from local dealers for round 2k cheaper. For a new BV10-46 incl. refl. screen and stand for round 7k. A use one from 2011 is round 5k and a 2010 is round 4k.
I think the latest BV10 does have the V1 technologie inside, the older ones not. But is it worth 2-3k?
LOEWE bild 5.55 OLED + AppleTV; BS4; BL9; BL8000 MKII all black
hotknife:I think the latest BV10 does have the V1 technologie inside, the older ones not.
None of the BeoVision 10 series (32 / 40 / 46) has "V1 / BV11 technology" inside! The main difference between earlier (2009/2010) and newer (end of 2010/2011/2012) models is:
The newer ones (Mk II or III) offer 3 HDMI inputs, the first versions just had 2 of them!
Vienna,
is there a difference regarding the panel quality? If it is the same, I think a 2010 BV10-46 with only a view hunderd hours would be the best option for me and I can save the money. I do not care if 2 or 3 HDMI sockets.
