Beogram 1700 tone arm wont lift
Karst1
Posts 11
Karst1 Posted: Wed, Aug 12 2020 3:04 PM
Hello.
I purchased a Beogram 1700 online.
And when i received it i discovered that the tonearm won't lift up when i start it up (press 33)
It just drags the arm towards the record.
It's the same if i put the arm on the record manually, it plays fine, but won't lift when the record ends, or when i press pause. There's just no movement up. The seller says it worked fine.
I have checked the counterweight. It's set on 1,5 (mmc20s)
I know there's been a few discussions here about similar issues, and that maybe i should try lubricating the arm. But i just can't seem to find any working links to show me how it's done.
Page 1 of 1 (1 items) | RSS
