Beolab 3 whistle / High Pitch Sound
This post has 30 Replies | 0 Followers
nethawk
Posts 20
nethawk Posted: Tue, Jul 12 2016 9:24 PM
I have a BeoSound 9000 + Beolab 3 connected with SoundsHeavenly PL MK3 10m cables.
I'm expericing a whistle noise, not a hummm. It's a high pitch sound.
Any idea? Both Beolab3 are power wired together.
Many thanks,
nethawk
Posts 20
nethawk replied on Tue, Jul 12 2016 11:34 PM
More information:
If I connect them with LINE cables it doesn't happen even if they are connected to the same power outlet.
Do you think it can be the cables? The Beolab 3? or the BeoSound 9000?
nethawk
Posts 20
nethawk replied on Tue, Jul 12 2016 11:41 PM
One last thing, it's a high frequency noise.
Some times it goes off for few seconds. But usually it stays all the time on, even if there is music.
elephant
AU
Posts 8,219
elephant replied on Wed, Jul 13 2016 2:47 AM
nethawk:
More information:
Did you flip the line switch back to pl ?
BeoNut since '75
nethawk
Posts 20
nethawk replied on Wed, Jul 13 2016 6:36 AM
Yes, one left and one right.
One is set to wall and the other to corner.
Thanks!
nethawk
Posts 20
Thanks!
nethawk
Posts 20
nethawk replied on Wed, Jul 13 2016 6:12 PM
any one have any clue? I'm desesperated!
L1NO
Posts 250
L1NO replied on Wed, Jul 13 2016 9:03 PM
All bang&olufsen speakers have a high-pitch 'noise' as gain (anplification) is open on full. This noticable in front of the tweeter and should not get louder if the volume changes. (Without playing music ofcourse)
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Wed, Jul 13 2016 10:53 PM
I'd try different PL cables. As for "all" of them having a whine, my BL9s don't, even when my ear is at the tweeter. No buzz, no whine. They're connected to a BS9000 using the appropriate PL cables.
Jeff
nethawk
Posts 20
nethawk replied on Wed, Jul 13 2016 10:53 PM
Hi L1NO,
I know that noise, and unfortunately is not that one.
I have tried to shutdown anything else around to search for any inteference and no clue what's going on...
nethawk
Posts 20
nethawk replied on Wed, Jul 13 2016 10:55 PM
Hi Jeff,
Which cables brand and model are you using?
Many thanks,
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Thu, Jul 14 2016 12:49 AM
I'm using a set of them I got from Sounds Heavenly, who advertises on Beoworld here. The ones I have are Powerlinl Mk 3, the ones with the little triangles on the plugs, designed for use with the later Ice Power amp speakers. I do know if you use the PL cables that don't have the triangles on them the Ice Power speakers will buzz. When I first got my BL9s I didn't have the right cables, I had old PL Mk 1 cables that I had been using on my BL8000s, and the BL9s had a high pitched buzz with them that went away with the proper Mk 3 cables.
Jeff
nethawk
Posts 20
nethawk replied on Thu, Jul 14 2016 8:08 AM
thanks jeff
while i didn't have the triangle, i bought pl mk3 from soundsheavenly so that should be fine.
I will buy a diffeferent set of cables just to try on and see if it makes any difference.
I was thinking of buying the bosscom 5,5m shielded. In some sites it says they are mk2. These also have the extra grounding for ICE speakers? or this is just on Mk3?
nethawk
Posts 20
nethawk replied on Tue, Jul 19 2016 10:01 PM
I have received a new set of cables just to make sure this wasn't the issue, and unfortunately this isn't the issue. The noise is still there.
I have been doing a lot more tests now as it was quite difficult before (my first set of cables are inside the walls).
It seems that when both PL cables are connected to the BS9000 there is one that only can output one of the channels. So if I change speakers from Left to Right and from Right to Left. There is one speaker that don't make any sound. If I change the PL cable from one speaker to the other, the one that can't handle both channels is the other one.
There is clearly something wrong in the BS9000.
Also depending which cable is set to Right or Left it makes the high pitch noise louder.
When I connect the speakers with LINE to a differnet sound source it works well.
Any one have had any problem similar with a BS9000?
Probably there will be a problem in the PCB32 that hosts the PL connectors. Any one knows how much it is?
Thanks,
elephant
AU
Posts 8,219
elephant replied on Wed, Jul 20 2016 1:13 AM
Have you tried daisy chaining the BL3s to eliminated the suspect BS9000 port ?
Not a solution but perhaps a work around ?
BeoNut since '75
nethawk
Posts 20
nethawk replied on Wed, Jul 20 2016 5:36 AM
I tried to leave just 1 speaker but there is still the highpitch sound (but less)... still not an option unfortunately.
nethawk
Posts 20
nethawk replied on Sat, Aug 27 2016 4:23 PM
Finally the B&O service center have repaired my BS9000.
It seems this is a known issue in some units and it was repaired FREE OF CHARGE.
No noise now!!! So Cool!
marexy
Posts 710
marexy replied on Fri, Dec 6 2019 7:47 AM
Hi guys
After a long time i did some connection BS9000 MK1 ( type 2526 SW1.4) + Beolab 3 MK1 ...and yes ...WT--F
And i have total the same issue. ( expericing a whistle noise, not a hummm. It's a high pitch sound. )
I did tray at least 8 different cables PL ( MK 1,2,3,...ect )...not better
And if i connect to BS 9000 speakers ..BL4000, 4, 6000, 8000 it is all fine.
So if any of you know what to do in BS9000 to repair that issue please let me know.
It is really really annoying :(
many thanks for help :)
marexy
Posts 710
marexy replied on Sat, Dec 7 2019 10:10 AM
Hi
Correction...on BL4 i have the same problem...and different BS9000 ..
So it is looking like BS9000  MK1 and new ice powe speakers are not BFF.
Any hint...or repair oprtions from you guys please.
thanks
marexy
Posts 710
marexy replied on Sat, Dec 7 2019 3:27 PM
News ..
have try BS 9000 MK2 + BL4 and BL3 ..no problem and no pitch sound.
So..there is sometning different at BS9000 MK1 on powerlink PCB or other PCB.
As someone post a info that B&O did some repair on BS9000MK1 for free..i think i have an opttion for DIY repair.
Any suggestions from experts here on forum  ??? :)
marexy
Posts 710
marexy replied on Sun, Jul 19 2020 8:15 PM
Hi guys :)
I know there are experts among you who know how to advise how to fix this.
Would be very happy if someone tells me the trick of what needs to be fixed or changed on the PCB where the PL connectors are in the BS9000 MK1.
I would love to listen to the BL3 on my BS9000MK1 but this sound is so terribly annoying that I have now had the BL4000 plugged in for a few months now.
Ask you for advice and a solution to the problem, you can also send personal messages.
Thanks for the help :)
Peter Pan
Posts 2,088
Peter Pan replied on Mon, Jul 20 2020 10:00 AM
Powerlink line adapter for Beolab speakers with line in via powerlink.
You can for eg. connect Beolab 3 speakers with a Sonos Connect.
Click here.
/ Peter Pan.
marexy
Posts 710
marexy replied on Tue, Jul 21 2020 6:41 AM
As mentioned, i use Powerlink cables not RCA to connect BS9000 and BL3 and here is the problem :(
I would be very happy if there was a fault in the cables, but unfortunately this is not the case, or it is possible to add something to the connectors to correct this sound.
In fact, the output on the PCB of the BS9000 MK1 and BS9000MK2 is one tiny small difference, and it can be fixed.
marexy
Posts 710
marexy replied on Thu, Jul 23 2020 7:32 AM
Some of the forum mambers have the same issue.
So i think that all BS9000 MK1 have the same old Powerlink PCB which are not compatible  with ICE power speakers.
Beouser66
Posts 47
Beouser66 replied on Fri, Jul 24 2020 9:24 AM
i thinking its the digital ground pin that are not connected, (pin 4 / blue wire and it can easy be fixad by connect it to pin 2
marexy
Posts 710
here is shematics from MK1 on the LEFT  and MK2 on the R.
Where is the difference ?
marexy
Posts 710
marexy replied on Tue, Jul 28 2020 4:34 PM
Beouser66:
That is not working. Try it, or someone with BS9000 MK1 and ice power speakers.That is not working. Try it, or someone with BS9000 MK1 and ice power speakers.
next suggestion please :)...WhistleBig SmileConfusedIdea
Beouser66
Posts 47
Beouser66 replied on Tue, Jul 28 2020 5:24 PM
sorry but i wrote wrong number should be pin 7 (blue) digital ground connect to pin 2
Beouser66
Posts 47
Beouser66 replied on Tue, Jul 28 2020 5:27 PM
About the schematics it should be the same all Beosound should work on icepower speakers, but maybe something wrong in PCB from factory or after..
marexy
Posts 710
marexy replied on Tue, Jul 28 2020 7:57 PM
I did exactly that. Pin 7 and it was actually worse than before.
So this is clearly not the solution. In fact, i am 99% sure that the difference is somewhere on the powerlink PCB.
Considering that the to one user on this forum one B&O service fix it for free, I'm sure the error is small but hidden.
Unfortunately, no one has shared this repair trick so far.
Sadly, this affects all ice power speakers.
marexy
Posts 710
marexy replied on Thu, Jul 30 2020 10:23 AM
I did try wit different option during the day...no progress :(
Page 1 of 1 (31 items) | RSS
