Hello!
I’ve just solved the compatibility issues between the beo 5 and the win10 and started to set up
my beo 5. Now the second problem... I’ve 2 beosound essence (possibility to connect IR-eye) and a beosound moment, but I can’t find this systems on the configuration tool (v6.84), any suggestions? thank you 🙏🏼!
Matteo
These devices were added after the Beo5/6 was discontinued. You will need to manually configure the virtual buttons. I find it easiest to just use some other audio system and then edit the buttons for name and IR command that is sent. There was a FAQ on the B&O site that listed what the Beo4/5/6 commands are for Deezer, TuneIn, Bluetooth, etc. sources on newer BeoSound devices. However, with the redesign of the website, I can no longer find that FAQ. Perhaps you or someone else knows what the Beo4/5/6 commands are. Otherwise, you can just test by trial and error with a Beo4 with the devices.
This link shows the Beo4 keys that control Beosound Moment and may help.
https://bogob2bda.custhelp.com/app/answers/answer_view/a_id/11418/~/how-do-i-operate-beosound-moment-with-my-beoremote-one-or-beo4-remote-control%3F
Stoobie
Thank you!
So I can program the beo 5 to use it with a beosound 5 and change the names of the buttons like they said in the link you send me?
I would say yes, that would work. It maybe a bit of trial and error but at least the Beo5 can be changed by you.
