Hi everyone, hope you can help. I put in the 00 menu on the remote and did a stupid thing... reset the tv and LOST everything on the Tv 👹
so .. the tv has a DVI connector for 720HD going in to the sky box and I have scart from sky+ box to Av2 in the tv. I also have 7.2 speaker cable from tv to speaker. The sky and tv with sound was great before I got stupid.
Can anyone tell me how I get it all back on to sky through the menu...option... connection
thanks
Danny
Press MENU
Select connections
Select AV2
Define the source as e.g DTV/SAT or V.MEM/V.TAPE depending on your preference.
Define HDTV as DVI
You should be done....
Pressing either SAT/DTV or V.MEM/V.TAPE should deliver picture via DVI and sound via SCART (AV2)
