I have been using the Line In/Optical on the Beosound Core as optical.
Now I want to connect a Beosound 9000 - PL out - to the Line in on the Core - this is now analogue.
I have searched for a Core technical manual and did not find one.
My question - what type of connecter must be used for Line in Analogue - is it a mini-jack or...
Thanks for the response ...
Best regards Rudi
For analog you can use a 3.5mm stereo jack (same that what is used for most headphones).
B&O in my life 😊:
Hi, thanks for your help !
